Hi everyone
I’m looking for a Drafts action that will take a list in Drafts and send it as separate actions to OmniFocus.
A list like this:
- Buy milk
- Sweep roof
- Walk dog
- Brush teeth
Anyone know if this is possible?
Thanks
Hi everyone
A list like this:
Thanks
A quick look in the Action Directory for “OmniFocus” gave this:
https://actions.getdrafts.com/a/1E6
“Send each line of the draft to OmniFocus as a new task. Each task must be confirmed in OmniFocus.”
I use the List in Reminders action and have OF set up to monitor a specific Reminders list.
This can run without needing to open OF for each task.
Here’s an action that just drops the whole note into the Inbox with no confirmation needed:
https://actions.getdrafts.com/a/1QO
(By adding a parameter, autosave, set to true, to the action above you can eliminate the need to confirm each task as well.)
On this topic, I found this Action that seems really useful, but it has a bug wherein a dash anywhere on the line will cause the line to be converted into a task, which I don’t think is the intended behavior. Based on its description, it’s only supposed to send lines that begin with a dash to OmniFocus, but any line with a dash gets sent (and the dash gets removed.)
https://actions.getdrafts.com/a/1Pw
For example, this list:
Meeting Notes
Attendees: Bill, Susan, John
- Put together design mockup
- Email client
Email should include billing info
Client address is 512 Wilkes-Barre Road
will be turned into the following OmniFocus tasks:
Email client
Client address is 512 WilkesBarre Road
That last one should not be a task.
I am not a coder. Anyone able to help fix that bug?
Hi. Yes that is my (admittedly somewhat repurposed) Action.
It could be fixed by changing the Task prefix to a character or string far less likely to cause interference. I personally opted for “-” as it’s a nice visual identifier that’s quick to enter. I’ve seen one with “OmniFocus:” or “OF:” used but that’s a little bit to fiddly for me when typing notes quickly in a meeting.
The section you need to change is:
const taskPrefix = “-”;
Change the “-” to another character. Maybe “+” or “~” ?
You could also use the JavaScript function startsWith
Thanks. That fixes this bug. Forgive my lack of JavaScript knowledge! I actually took and repurposed it from something @clarke posted to the community.
Sorry I haven’t yet credited @clarke So thanks!
This action is updated.
I suspected that might be the case! Repurposing existing actions is a great way to learn
