I’ve owned Drafts for probably 9 years, but embarrassingly I just started playing around with x-callback-url
's
. I’m using it to run a Shortcut that saves the Draft as a text file into my iCloud Drive. It works.
The problem is that after success, when Drafts.app re-opens the Action panel remains open. I think it used to close automatically. I can’t figure out if this is a bug or if I need to pass back some return value/parameter to get the panel to close on success?
Here’s my Action:
Callback URL Template:
shortcuts://x-callback-url/run-shortcut?name=Save%20to%20iCloud&input=text&text=[[draft]]
If you want to force the action list to close, even if pinned open, you can use a script action containing app.hideActionlist();
If your action list is set to auto hide, then you probably just need to switch the focus away from it and back to the editor. You can do that with a script action containing editor.activate()
Drafts does not automatically close the action panel after actions are run.
If you want to explicitly force that, you could end your action with a script action step that calls app.hideActionList()
docs.
Note, for reference, there is a Run Shortcut that is a little easier to configure than constructing your own x-callback-url.
@agiletortoise Whoo hoo
That was it! Thank you (and @sylumer) for the kick in the right direction.
I added a script step containing this single line: app.hideActionList();
and that did the trick.
I did originally start with Run Shortcut but was just testing the x-callback method to see if that made any difference re: my original problem. I’ll switch back. Thanks again.
