Hi,
Thank you for releasing Drafts for mac, it looks terrific. However, it doesn’t seem to support the Mac OS native keyboard replacement feature ; it makes it difficult to use for me as I write a lot with shortcuts.
Any tip on how to solve the issue?
You mean the text replacements you configure in System Preferences > Keyboard > Text? Those are supported. No problems using them in Drafts here.
Thank you for your answer. Yes, I mean those. For some reason it doesn’t work for me.
It’s solved. All it took was… to reboot. Classic. Thank you again.
