Is there a reason why I am losing the bottom left-hand corner of my screen when using drafts on the iPad? It means that the menu showing my other draft titles are obscured.
I can’t work out why it’s happening
It’s a bug.
It’s mostly an iPadOS bug.
Tends to happen moving in and out of different split/slide over views, because the OS fails to deliver the right notifications to Drafts about the keyboard being hidden.
If you do something to make the keyboard appear and disappear again it will fix it when it happens. I’ve worked on the issue a number of times, but have not found a good workaround to make sure it never happens.
