I’m grabbing the value of the datePicker with this:
var startDate = p.fieldValues["myDate"].toString("yyyy-MM-dd");
I’m then looping 7 days… and in order add the iteration to the date I’m doing this:
duck = new Date(startDate);
tmpDate = duck.addDays(i).toString("MMM dd");
Date.prototype.addDays = function(days) {
var date = new Date(this.valueOf());
// console.log("date in function: " + this.valueOf());
date.setDate(date.getDate() + days);
return date;
the problem I am running into is that if the date pulled from the picker is “2019-05-13” when I pass that into the new Date()
It’s giving me a date 4 hours earlier "Sun May 12 2019 20:00:00 GMT-400 (EDT)
any suggestions?
I was able to get it showing the correct date/time by using this :
duck = new Date(startDate.replace(/-/g, '\/'));
Apparently the date having “/” in it instead of “-” returns it properly without a timezone offset
¯\(ツ)/¯
Note that Drafts ships with the Date.js library, which makes date operations pretty easy. No need for your addDays
function, it’s already available out the box in Drafts - along with a lot of other handy date functions.
I would tend to discourage you from going back and forth between dates and strings unless necessary, because you can get some unpredictable results. p.fieldValues["myDate"]
will just return a date from a Date Picker field, no need to make It a string and then a date again.
ah,. gotcha. I was converting it to strings for display purposes, but I can do that later when I put it into the calendar bits… Thanks for the reply.
