I think this script by @scripts4drafts for sending the line under the cursor to Reminders is fantastic.
However, I’m wondering if it’s possible to customize it so that multiple lines could be selected in a draft, then the action would parse that so that the first line would be the task title and the remaining lines would be the task note. If I was doing this to a draft, I would just use the [[title]] and [[body]] tags, but I don’t know what to do when working with a selection …
Here’s the actual script for convenience:
let [loc, len] = editor.getSelectedLineRange(),
str = editor.getTextInRange(loc, len),
icon = '🔘',
reminderList = 'Inbox', // pick the Reminders list you want
list = ReminderList.findOrCreate(reminderList),
reminder = list.createReminder();
reminder.title = str.trim(); // trim gets rid of end of line (\n), if any
reminder.notes = new Date().toISOString(); // date or whatever you want
reminder.update();
newStr = icon + ' ' + str;
editor.setTextInRange(loc, len, newStr);
// move the cursor to the end of the edited line
editor.setSelectedRange(loc + newStr.trim().length, 0);
editor.setSelectedText('');
// activate is not required if the action is launched via a keyboard button
editor.activate();
Hi @derekvan,
Thank you.
I wrote the following script so that each selected line is sent to Reminders.
str = editor.getTextInRange(loc, len).replace(/\n$/, ''),
lines = str.split('\n'),
icon = '🔘',
lines = lines.map(function (line) {
let reminder = list.createReminder();
reminder.title = line.trim();
reminder.update();
return icon + ' ' + line;
let newStr = lines.join('\n');
editor.activate();
Let me write another one to answer precisely your request
Here it is:
title = lines[0],
body = lines.slice(1).join('\n'),
icon = '🔘',
reminder.title = title.trim(); // trim gets rid of end of line (\n), if any
reminder.notes = body;
reminder.update();
let newStr = icon + ' ' + str;
editor.activate();
Phenomenal! Thank you so much for doing this. This also helps me work out some more flexible techniques for grabbing selections.
you’re welcome
I published the scripts in the Action Directory:
