Is there an action somewhere that can create a contact within the iOS contacts app from a draft? Something similar to the actions that allow creating calendar events or reminders etc?
Would appreciate being pointed in the right direction or any help with creating something.
I haven’t found an action in the directory, nor have I seen anything in the Scripting Reference. I believe it’s not quite possible right now. I’ve found stuff that works with Cardhop but that won’t really solve your issue.
Thanks for this info. I actually downloaded Cardhop to test this functionality. It’s pretty perfect and exactly what I was looking for. It’s also supported by the free version. Maybe I’ll start use of Cardhop full time, I don’t know. But for now this at least works as a conduit to add stuff to the iOS contacts app, as it’s connected.
@agiletortoise - have been playing around with the add to Cardhop action that was suggested by @motopascyyy- I wondered how configurable it is (by someone that knows about this stuff - not me really!)
For example, I generally want to add a prefix, and name, a number, an email and then a note. How can I dictate what goes where? The note just gets spread out amongst all of the other address fields etc.
Is it possible to some how use a system similar to your excellent scratchpad suggestion?
I’m not especially familiar with CardHop. I know it can create contacts, but thought it was more designed around acting on your contacts. It look like, from their docs, the have just the one method that takes a “sentence” to parse – so, I would assume you need to write your draft text in a form that is the same as something you would type in CardHop directly.
Do not know what/if they have support for those more advanced fields.
