hello, below is a script by Chris Montgomery to append list of tags to a draft. I was wondering if it would be complicated to change from append to draft to insert tags at cursor. thank you
/* global draft */
- Tags to Hashtags
- Converts Drafts tags to hashtags and appends them to the content if the
- hashtags aren’t already present.
- Has the same single-word hashtag limitation as similar scripts. Any Drafts
- tags containing spaces will be converted to a hashtag with no spaces. Why
- would you want a hashtag with spaces anyway?
- Basically does the opposite of @derekvan’s “Tag drafts by hashtag” http://actions.getdrafts.com/a/1Q7
- Based on @kjaymiller’s “Add Hashtags from Inside of Draft” action http://actions.getdrafts.com/a/1ME
- @author Chris Montgomery chris@montchr.io
@link https://actions.getdrafts.com/a/1Uu
const { content, tags } = draft;
if (tags && tags.length !== 0) {
const spacelessTags = tags.map(tag => tag.replace(’ ', ‘’));
let newTags = spacelessTags;
