When specifying a physical/external keyboard shortcut for an Action, the arrow keys aren’t able to be specified as shortcut keys (presumably because the field is consuming them as cursor-movement events).
Bumping this (mostly in hopes that there’s a way around this limitation). Would love to make a ⌘⌃↑/↓ shortcut for this action and its partner to mirror the functionality of my text editor. I might wind up setting this up on macOS through the system keyboard shortcuts, but I’d miss it on the iPad.
I just ran into this problem when trying to assign a shortcut using arrow keys to the next marker and previous marker actions recently made available. The best workaround I could find was to make control and + (and control and -) as the keyboard shortcuts. It’s working well so far.
I’m trying to use Cmd-Ctrl-Up/Down/Left/Right as shortcuts for different actions but haven’t figured out a way to insert any arrow key using the UI?
Is this something that still isn’t possible two years later? Are there any workarounds… perhaps specifying the shortcut combo within a script?
Thx
+1 for this. would be great for my actions to move lines of text up and down, as well as the indent and outdent actions. thanks!
Thanks so much for putting this into v22! Patch notes implied to me that it was an iOS ≤13 restriction. Can’t wait to get a chance to sit down and tweak my Drafts set-up soon.
