Can’t figure out why the save to drafts action is creating a new folder rather than saving to where is specify?
I would expect that action to create a file in Dropbox something like:
/Adrian's Blog/Posts/2019-05-29 First Line of Draft.txt
Is that not what you are getting? What is the output? It should create the “Adrian’s Blog” and “Posts” folders if they don’t exist already, otherwise just place the new file in that existing folder.
It creates the file. The problem is I already have a folder called “Adrian’s Blog”, but the action creates another folder every time.
Sure the path is an exact match? (Possible the smart quote should be a straight quote?)
THAT WAS IT. THE SMART QUOTE. GOT IT WORKING NOW. THANKYOU SO MUCH!!!
Can’t believe it was something so silly.
