Running on an iPhone 7+ and the app just generally feels a lot pokier than it used to, primarily when interacting with other apps. If I save text from Safari via the share bookmarklet, it’ll take 3-5 seconds to appear. My taskpaper > omnifocus action chugs along when it used to be very swift. Anyone had similar issues?
Yeah facing the same on my iPhone 7. Some help is appreciated.
Thanks in advance.
Regards,
Shane
unfortunately i had to upgrade on the omnifocus side (much of it was an OF issue). the app was nearly bricked it was running so slowly… really not thrilled about it.
I have not done a lot of testing on an iPhone 7 using iOS 13, but have done quite a bit on an iPhone 8+ and have felt like things were pretty slow all around - not just Drafts, but more or less everything. Are you saying you are having specific issues with Drafts being slow when other things seem fine?
I find iOS 13 (actually iPad OS 13) on my original 12.9” iPad Pro slower in general. So it might ha nothing to do with Drafts.
